Thread: ECU From '07 ZX14-Will it Fit/Work?
Created on: 02/01/13 12:48 PM
zx1441xz
zx1441xz's Gravatar
02/01/13 12:48 PM
Hello All,
A buddy of mine is parting out an '07 ZX and I am considering purchasing the ECU to have it flashed and keep my stock as a backup. Will there be any problems? Also, what would be a good price to offer?
Sorry if this topic has been hammered to death.
dragking
dragking's Gravatar
RE: ECU From '07 ZX14-Will it Fit/Work?
02/01/13 4:33 PM
WOW. I'm the wrong person to answer this, but I think you're asking too much. There has to some parameters typical to the 1st generation that a re-flash won't over ride. Just send your ECU to Guhl or if you live close, ride over there, I don't think you will regret it. I will be sending mine. Check ebay, there are a lot of cheap ECU in case you don't want to make your buddy an offer he CAN refuse.
hagrid's Gravatar
02/01/13 9:23 PM
Too many differences between gens 1 and 2 to make what you are proposing feasible.
Traction control functionality to name one.
Yoshis!! GO NINJEE!!!
02/01/13 11:03 PM
The firmware COULD be in there already.Who knows?A zx14 2009 with abs?Hmmmmmm.The frame holes are identical for fitment of the abs hardware;)The abs units are for sale...including piping.The calipers are the same mounting spots.Maybe all that earlier ECU needs is an unlock of a program?????The Connie's had ABS for how long now?Those tone wheels....wonder if they fit an earlier model zx14.....ooppps...got off subject here a tad....sorry.
* Last updated by: Grn14 on 2/1/2013 @ 11:05 PM *
02/08/13 9:12 AM
Here's the mix and match for this one.
2006-2007 = 440cc injectors
2008-2009 = 330cc injectors
2010-2011 = ??
2012-2013 = Totally different animal having to do with the auto-idle system. No more needing to set the idle with a cable. So you need that ECU and that throttle body to mix and match these gens.
So yes, swap the matching ECU w/injector between gens. That means you'll run rich if you use an '06 injector with an '08 ECU. No problem with all the sensors. I believe they are preset with the same output numbers. So no worry about changing those.
